hi friends ,Ihave a marshall vs 100 combo thats only work the clean channel, I clean all the pots ,inputs,outputs ,swich and change the tube and I donīt know what can I do more.thanks a lot.
marshall vs 100 need help
Check the output pins of ALL your op amps for unwanted DC offset voltages. Re,e,ber most of your op amps are dual, with outputs on pins 1 and 7.
Failing that, apply a test signal of some sort and trace it through the channel with a scope. No scope? SIgnal traceer? Not either? Set your meter to AC volts and follow hte signal with that. Since your problem in the bad channel is no sound, then all we need at any point in the channel is signal or no signal indications.Education is what you're left with after you have forgotten what you have learned.
