Marshall AVT275 - No Sound From Main Speakers
    Enzo, Techineer,
    More sound advice - helping me keep my head straight here....
    As above, I did assume they looked to be .25w due to being so small, obviously size isn't everything....! They do specify a minimum 10mm clearance from the PCB,which I have observed.
    IF they were .25w, I'd thought replacing them with a larger .5w would be a safer idea.
    Looks like you're both right, I should go withthe schematic value, and use 2.2ohm 1w....
    Back to RS again tomorrow (as I'm in the UK).
    I'll get there eventually....
    Thanks,
    Johnny Creeper
      Marshall AVT 275 Sounded very low...need help
      I have AVT275 with very low output volumes, only sound from OD1/OD2 no sound from CLEAN or AC SIM. Master volume turned pass 12 O'clock or more and only get less than 10% plus noises. Need help to trace the root of problems. As I trying to duplicated of Creeper's experiences .... Thanks for your help.
