The irony here is that I wasn't working on an amp, just recording with one.
While recording electric guitar I went to check and see that I was plugged into the correct jack on the cab - one of them is very loose. I muted my strings with my right hand, and soon as I touched the metal casing on the cable I felt a horrible shock through my chest.
After the initial frustration wore off, I decided to troubleshoot. I turned on the amp and checked for AC and DC from ground to cable - nothing.
I then checked from the guitar strings to jack, and got a reading of -120 VAC, a reading, which I couldn't reproduce when checking again.
I also checked to see if the out let had a bad ground, but that was okay too.
This was my signal chain:
Guitar -> tuner using 9V ungrounded power supply -> amp
All power was coming from a Furman power conditioner.
Any ideas why I was shocked? I've never been shocked while working on an amp because I know how to do that safely enough, but this seems totally random. Thanks for any advice.
-Alex
-Alex
