New Month We are at $45 this month in Donations.Please consider making a donation. :)
Happy NEW YEARS!!!!!!
I have a 70's Peavey 400BH that blows the fuse after about five or six seconds of being turned on. I can hear it draw down power on a small fan I have plugged into the same outlet. Any Ideas
Disconnect the secondaries from the board - the oprange wires, and the red wires - and power up. Does the transformer running alone like this still pop fuses?
Look up "light bulb limiter." Make one. Use it.
Or use a variac and ammeter.
If the transformer is OK, connect the orange wires. only. Blow or no? Then the red ones.
All outputs "appear" to be good? None measure shorted on a meter?
Check ALL rectifier diodes in the powr supply. ANy shorted?
Make sure CR9, CR13 are not open, and that the connections to CR13 are OK.
