My X100B has a 15 volt +/- supply that works the op amps and the 4049.I am getting +10 where I should be getting -15.I have replaced all components and its still getting +10.When I hook up the foot switch the switching functions work like its getting a ground it needs from the switch connection but it still has the 10 volts.It has a bridge rectifier from the transformer and at the diodes and caps after it the -15 is there.Checked the tranny and it is fine.It seems there may be a 0 earth ground getting into the - 15 rail but after tracing it many times I still cant find where.I use this amp a LOT.I really need it up and running so any help would be greatly appreciated.
Schematic is here
Schematic is here
