Hoping someone can help me. I recently purchased a 50 watt Hiwatt Head, and within a day I blew the fuses. The fuses we changed and the amp was fine...for another day. In the middle of playing, the amp just cut off. I wondered if I could have possibly blown the fuses again. I switched them out with two new ones, and nothing. Other than the Led light on the front coming on, nothing happens. Any thoughts? Before I take it to a tech, I thought someone here might have a suggestion on what it could be.
HIWATT Amp Problem
It's difficult to guess without a model number. If it's a tube amp, it's probably a bad output tube(s) drawing too much current and blowing the fuse. I see the DR504, SA112, SA115 and SA212 all used a pair of EL34s in the output. You can try putting in a new set of output tubes and see if that helps.
Replacing the fuse won't help until you solve the problem.
Originally posted by techineer View PostIt's difficult to guess without a model number. If it's a tube amp, it's probably a bad output tube(s) drawing too much current and blowing the fuse. I see the DR504, SA112, SA115 and SA212 all used a pair of EL34s in the output. You can try putting in a new set of output tubes and see if that helps.
The diagrams that I have found don't show any adjustment for bias. That's why I didn't mention it.
http://www.hiwatt.com/data/tech_info.html
