Capacitor codes?
  • Capacitor codes?
    Is there a site that will explain the codes on capacitors? I am specifically interested in finding out codes on asian made electrolytic caps. Thanks!
    Axtman,
    May not be specifically what you're after, but theres a fair bit of useful info on this site;
    Badcaps.net - Badcaps Home
    Although primarily dealing with electrolytics used in PC motherboard manufacture, many of the same manufacturers make caps of varying styles and sizes for use in other kit - I've certainly seen the same 'makes' in amps that I've seen in HP Compaq servers....
    Hope that helps in some way....
    Johnny Creeper
      This may be useful sorry its a bit big..Wagner Electronic Services here in
      Australia had this in their catalogue.
        The main thing to know is unless otherwise noted by a decimal pout or some other symbol, cap values are often shown in picofarads - pf. SO when you see a number on a cap like 223 or 104, consider it like a resistor color code: value, value, multiplier. Multiplier is the same thing as number of zeroes.
        So 223 means 2-2-000pf, 22,000pf, which is the same as .022uf. And a 104 would mean 1-0-0000, or 100,000pf, which is the same as .1uf.
          Mr. Creeper,
          You read my mind. I did come across some bulging asian electrolytic capacitors in a modern bass tube. I replaced them and the hum went away. I should have upped the capacity from 100 uf to 220 uf to give the amp more "guts".
          casinolevant levant casino
