Hi,
I have just bought a Bugera 333XL with the 4x12 cab and have a problem out of the box. This is my first stack amp so I am wondering if I have missed something obvious.
When I power everything on it works fine for about 60 seconds. Then I get a popping noise every 10 seconds which will quicken to up to 3-4 seconds. This happens with no guitar plugged in and all settings at zero. It stops if I turn standby off.
It came with EL34's which are currently biased to about 44V (which I think is a little high - the Bugera manual provides different voltages for different tube grades and I dont know which one to use). I have plugged in the cab and set the speaker switch to 16ohm. The cab has been set to mono and a guitar cable plugged into the input (ahem).
Do any of you guys have any idea what I could be doing wrong or what could be wrong with the amp itself?
Thanks
Mike
Thanks
Mike
