AVTt 150H Was blowing fuse. I disconnected all connectors to output boards and fuse is no longer blowing. Headphone output is straight noise similar to pulse wave unaffected by volume and other controls. Power switch lighting but other switches not lighting. L101 seems to be getting hot quickly.
Marshall AVT150 Blowing fuse
Those don't make sense. What are you using for a ground reference for your meter?
The three-pin connectors should have +VE and -VE and output. WHen unplugged from the modules, the output pin should have zero on it, since it is no longer connected to anything but the speaker jack. Are you taking these readings with BOTH powr modules disconnected?
Where is that 68v coming from?Education is what you're left with after you have forgotten what you have learned.
Look at the schematic.
The low voltage secondary wires go to commection points W106, W107, with the center tap to W105. The high voltage secondary wires go to points W103,W104, and center tap to W102.
DOn;t ask me were those are on the board, I have no idea. The designations should be silk screened on the board.Education is what you're left with after you have forgotten what you have learned.
