Hello fellow ampagers!
I have had the power tranny of my mid-60s Silvertone 1482 amp rewound.
First thing: there is a new wire that wasn't there in the original tranny. The tech called it "grid". Any idea of what this wire is for? I left it unhooked for good.
Second thing: the heater wires have slightly different, and higher than stock, tensions: about 6.6 and 6.4 Vac, measured with no tubes in place.
Third - and most important - thing: I turned the amp on for a first check, with only the rectifier tube (an RCA 6X4) on. After less than one minute there was a weak crackling noise and the tube lit off. The heater and AC voltages are still there, but the tube shows no sign of life (no dc high tension). Also, the power light shut off shortly after the recto.
What can cause a rectifier tube and the power lamp to die when the ac voltages are fine?
I'd love to find the cause of failure before putting a new 6X4 in the amp.
