I have a 63 Deluxe model AA763 in serious need of some TLC, and I have some questions. The tubes have been replaced, but I still need to tension the sockets as they are all loose, which I assume is causing intermittent noise. The filter caps are also fairly new, replaced last year, and have less than 10 hrs on them.
Anyhow, I'm thinking that while I've got the thing open, I need to replace all the electrolytic caps inside. I'm only 15 minutes from Antique Electronics, so I'm hoping to get all my parts there. The 25uf 25V capacitors in the amp are combined (not sure of the term, but there are 2 caps in the cans). I'm assuming it's okay to replace these with singles, such as the sprague atoms. Also as for the others (blue ones in the pics), several sites have similar capacitance values, but higher voltages. Does the voltage make a difference as long as it is the minimum on the schematic?
I'm also going to replace the resistors on the power tubes as I read elsewhere that this was recommended.
Are there any recommendations on the caps, brand or otherwise? I've seen kits that have all the caps on the Kendrick site, but it looks like it would be cheaper to just order the stuff individually.
I'm also in need of a new speaker, since due to carelessness, I dropped the chassis, tearing out the speaker wires, managed to stop the chassis from hitting the floor though. I'm thinking Weber, but have not experience with these.
I've included pics of the chassis, it already has a 3-wire cord installed. Should I replace the cap under the ground switch, or does the new cord negate this?
Sorry for being long winded, but I'd like to get this right the first time, and would appreciate any input.
Thanks,
Ken
Thanks,
Ken
