I seem to have frequent troubles with power trannies...
While I haven't yet solved the heater supply issue in my Silvertone 1482, I have another problem in my '79 Fender Vibrolux Reverb.
This amp used to work fine. All of a sudden, after two or three turn on/off cycles at a gig, it wouldn't turn on anymore.
Same at home: after on/off switching two-three times the amp doesn't turn on any longer and the PT is very hot. At last it hasn't turned on at all.
While the power cord delivers the correct AC voltage, there is no voltage from the PT secondaries: neither high tension nor 5V or 6.3V heaters.
I have also bypassed the VAC selector (this is the export version of the amp) in case it was shorting to no avail.
How do I tell if the power switch got broken or if rather there's a short inside the PT? Is there any chance that the voltage is interrupted somewhere before getting to the PT?
I attach a sketch of the power supply section of this very amp version.
