After eliminating tubes, what are the usual culprits that could contribute to gain loss in the preamp section? My SFPR is putting out a strong 14.5 watts, but it recently has dropped a lot of volume and bass. The tone used to be very substantial and beefy, and now it is very whispy and the bass has gotten way farty. I can crank it to ten and still talk over it. It used to peel paint off the walls on 4. It feels like I've lost a stage of gain somewhere. The power tubes are biased up fine and I had the output checked at 14.5 watts. I had an amp tech test it and he says it's okay, but it just doesn't sound right or feel right.
Missing gain in Princeton Reverb
The trace a signal through the amp. Chances are something about the work you did is not right. A missed connection perhaps, and you are hearing crosstalk instead of the complete signal path.Education is what you're left with after you have forgotten what you have learned.
COuld just be solder, sure. But those cathode caps can dry up easily over the time that amp has been around.
Yes, your cap can "test" OK and still be worthless. The cap function on a hand meter usually just reads value, and even that is inferred. it doesn't put real world conditions on a cap, and it doesn't check for ESR. In fact, in some gear I used to service, worn out caps often read high! SO that 22uf cap might measure close to that, but when it tried to function in a circuit it was unable to perform.
ALL of that is moot if your solder connection had failed of course, but that is how your part can check OK but not be OK. Like so many testers, if a hand meter tells you it is bad, it probably is bad, but if it says OK, you don;t really know.Education is what you're left with after you have forgotten what you have learned.
