I got a Sovtek mig 60 for my Son for Christmas. It was described as having a mod that added a little gain. The seller was supposed to send a diagram showing the mod with the unit, but I don't know if I will ever get it. My son says he wants a little less "crunch" ( I assume less gain/distortion). Could I accomplish that by putting in 1 or 2 12at7 rather than the 12ax7 as they have a little less gain? Or, is the gain produced only in the EL 34s? Would that impact the power output or just the tone?
Second question. I need to replace the Mullard EL34s in a Hiwatt he has. It doesn't have auto biasing so I probably want to get tubes approximately the same as the Mullards. I notice tubes often have reference numbers on them such as 28 up to 40. Would a higher or lower number be more likely to be closer to the Hiwatt bias value? Does the higher number represent a higher current draw or a higher internal impedance? Thanks for answering some dumb questions.
