Well I've got this Marmac XL120 Amp head which is in need of some repair. I got it from an old shed I was looking through and after searching the net, some people seem to like how it sounds so I am gonna try and fix it up.
The amp was manufactured sometime in the 70's/80's in Glenamaddy in Ireland. The shop which used to make and sell them is still there, but they stopped making them a good while ago. The transformers are all hand wound.
When I first got it I replaced some of the fuses in it and turned it on. I got the glow from the valves and the power and standby LED's came on, but got a good bit of smoke coming from inside the amp. After testing the circuitry I think it might be that the transformers are blown. I have some pictures below which I hope you can have a look at and see if you see anything blatantly wrong with it.
Any info/advice/guidance on what to do would be very appreciated.
Thanks a lot.
(click for larger)
Thanks a lot.
(click for larger)
