Anyone got any pointers bout the best place to start checking faults in the preamp of the hotrod deville? or any problem parts that tend to blow?
Heres the problem... BOTH channels have hardly any volume, even cranked all the way up... the power section seems fine, as when plugged direct into the "power amp in" I get good volume, and the reverb works too...
So it seems the problem occurs somewhere before the power amp in jack...
heres what i checked so far...
- Changed all the tubes, but with no success...
- Plugged preamp out into poweramp in.. (to bypass jack switches) Still no luck...
- Checked the contacts of the "poweramp in" jack, pins 4-5 make perfect contact. (connecting preamp to poweramp)
- Checked connections from pin 4 of the "poweramp in" jack back to the channel switcher... all connections good here too...
Another odd thing... when i turn the amp on from standby, the amp makes a wierd electrical "insect" noise... not from the speakers, but from somewhere in the chassis.... sounds to me like somethings broke, or shorted.... I dunno..
I'm kind lost, it's gonna be a lot of work checking all the connections in the preamp, so I thought I'd see if anyones been here before and give me a heads up on the first places to check!
thanks!
thanks!
