I have another Kustom Kasino in the shop, this time it's one that someone traded me for a credit on a repair.
For the purposes of this issue, I am working from this schematic:
http://music-electronics-forum.com/a...om-pc5129-.pdf
Trying basic signal chasing, what I see is that my sine wave gets no further than the base of Q1. The DC voltages on the terminals of Q1 do not match the schematic, either.
Q1 e=1.07VDC b=.7VDC c=11.6VDC
What I have done so far is replace CR1, CR2, C1, C2, C4, C6, R1, R3, R7, R8, and R10.
R2, R4, R5 measure within tolerance. R9 is specified as 200 on the schematic, but is installed as 2K2.
Q1 and Q2 check out good using my Hickock in-circuit tester and using the diode function on my Fluke.
I've also replaced all tantalum caps with new electrolytics.
Interesting note: the other preamp PCB,
http://music-electronics-forum.com/a...tom-pc5128.pdf
....displays the same flat line after Q1 as well as similar DC voltages. I tried replacing its Q1 with a 2N3904 with no change in behavior.
One slightly weird thing about this input circuit is that the sleeve of the input jack is not explicitly tied to ground on the schematic. I've tried variations of inserting a cord to make sure everything was floating, using an ungrounded battery-operated signal generator, etc, with no change in behavior.
Where would you go from here, gang?
