Hi Folks,
I have a problem with my Peavey Classic 50/50 amp...
It kept cutting out under very heavy load (big loud notes would fold up into silence)
I noticed that two of the valves on the second channel were glowing very bright red in an alarming manner when I pushed it
I thought it might be the valves, so I put in 8 fresh EL84's... Valves are now even brighter & now three are not happy...
It had also burned out the 10K resistor next to the bottom right (from front of amp) valve on channel number two... when I replaced it & brought it back up on the variac with a test 1k sine wave it promptly burned out the10k on the bottom left...
Normally I would blunder about testing every component until I find the dud, replace & repeat until it was fixed, but I am in kind of a hurry for this one to be working as I could do with using it on a session I am in at the moment...
Any Ideas?
Many Thanks
Nick
Any Ideas?
Many Thanks
Nick
