Tektronix 475 Oscilloscope
  • Tektronix 475 Oscilloscope
    Don't know if this is off topic,..... If it is I will delete it right away.
    but here is the deal.....
    The display and fan just stopped working...any ideas?
    The 3 small UNCAL lights come on.
    The 2 fuses are good and the selector switch bar is in the medium position and test good.
    Thanks
    Doc
    I'd say you have a powr supply failure.
      Maybe these forums can help you.
      tektronix forum: Tektronix Forum • View forum - Oscilloscope Technical Support
      Antique Radio test equipment forum: Antique Radio Forums :: View Forum - Test Equipment Discussions
        Thanks, Enzo.
          Thanks, Axtman...I'll check those sites.
            Doc,
            Check out the Tekscopes group on Yahoo. Several retired Tek employees over there. I have a few Tek scopes, and they've been a big help to me in repairing them.
            TekScopes : All about classic Tektronix CRT o'scopes
            - Yogi Berra
              Check the caps
              With a scope of that age you can look right at the filter caps. Tek scopes often have a shutdown feature that will kill the supply if ripple exceeds an overvoltage limit.
                Many times in a Tektronix scope one power supply is adjustable and all the other (usually 5 or more) supplys use it as a reference and their voltage is determined by 1% resistors. If that supply dies, all the others go down except some loosely regulated supplys for panel lights. I may have a service manual for the 475 or have access to one. It will take a couple of days to look for it.
                  Couple of sources for Tek Manuals:
                  http://bama.edebris.com/manuals/tek/
                  Tektronix Service Manuals
                  - Yogi Berra
                    I have a 475 200mhz version with the DM44 meter on top. Works fine with the exception that the trace doesn't seem to be as fine as it should...IE a little too tall when focused. I'm sure its due for a cal and some cap replacement. Paid $25 for it with a bunch of probes. I keep it as a backup. Haven't needed it yet...the trusty B&K just keeps on a-goin'.
                      Most Tek scopes that dont use tubes like the old 500 series have a screen mesh in the CRT order to get the high bandwith, this does cause the trace to not be as sharp as the older tube models.
                      - Yogi Berra
                      casinolevant levant casino
