I did a search and found some info, but I would still like to verify. Regarding a 12ax7, they are rated at 0.15 series and 0.3 parallel. I assume they are referring to how the tubes are wired in relation to the transformer and not how the tube is wired relative to itself. So it would be parallel, at 0.3 per triode in a 12ax7. The 6L6 draws 0.9 amps per tube. The 5ar4 soaks up 1.90 amps, according to the book I have.
So how do you figure what gage heater wire to use? I know 18 gage is kind of standard. But how does one get to that number, and not 20 gage for example. How do I figure it out?
5AR4 x 1
6L6 x 2
12AX7 x 3
Thank You
5AR4 x 1
6L6 x 2
12AX7 x 3
Thank You
