I've got a Royal Guardsman head that I re-capped and the output drops out about once a second, as if the tremelo is on, even though the tremelo is turned off. The dropout occurs at a rate independent of the tremelo setting; it's constant. And it is much slower than the tremelo will actually run. If I disconnect the preamp from the power amp, the problem goes away: the power amp output is fine and so is the preamp's output. Once I connect the two together, the problem comes back. It seems to affect the rails, but only when the 2 pieces are connected together.
Any ideas?
Any ideas?
