On a Hartke 3500 , with the 2SC5200/2SA1943 transistors, does anyone know what the AC current draw from the mains is.
No signal, no load.
I have one on the bench that is pulling 3.5 amps.
I disconnected the +- 80 volts to the power amp. Removed the 12AX&7 tube.
The only thing left is 11 opamps & the + - 15 volt regulators.
+ - 15 volts is steady. No ripple. No diode shorts. No hot opamps
I guess it's time to start yanking opamps.
No signal, no load.
