combo amp speaker question
  • combo amp speaker question
    i have a behringer gmx212 combo amp. i have used it for almost a year and no problems. i quit using it for two weeks. it was unpluged in climate controlled area. now only the right speaker works. i have tried different guitars with different cables and still the problem remains. can somebody help me please
    There is an amp for each speaker. Plobe a plug in and out of the slave in jack for that side a few tiomes. Does that wake the dead side up? Likewise, plobe a plug in and out of hte extension speaker jack for the dead side a few times. ANy help?
    Plug your guitar into the slave in jack for each side and see if sound comes out each side.
      plugged into slave in on dead side and it works but a sizzle sound coming from it. plugged back into input speaker still doesnt work. also tried your other suggestions .wonder what it could be
        My guess is most probably a bad solder joint?? Behringer uses crappy unleaded solder (because of Euro RoHS requirements) which is brittle and prone to other problems.
        casibom betturkey
