Hello, I am kind of new to posting a question, so here goes.
I recently acquired a Peavey Classic VTX 65 watt amp. It’s looking like there are some problems with it.
There are 2 channels on the amp. “Normal gain” and “Lead gain”. By default the Lead channel is active when you do not have the foot switch. To activate the Normal channel, you need the foot switch. Unfortunately I do not have the footswitch to this amp. The way I was able to activate the Normal Gain channel was to jump a wire on the rear DIN connector(6 pin version) from pin 4 to ground. I’m also able to turn reverb off by grounding pin 2 and for the phase I’m able to ground pin 3. I still have not been able to determine how to activate both channels simultaneously. I think that is one of the features of this amp. I have also heard of this being referred to “warping”. I look to build a footswitch for this amp. I noticed a couple issues.
1. When Normal Gain is active, the volume for that channel is acting strange. I turn it to position 1 and its immediately loud. Then form position 1 – 6 there is no variation in the volume. Then from pos 6 – 7, it gets super loud.
2. The second issue is with the phase. When I activate it by turning up the depth and range, I can hear slight noisy oscillation but there is no depth. When I play a chord, the effect is next to nothing. I think the circuit is oscillating but there is something wrong with the depth control. Pots for both controls seem to be good according to an ohmmeter.
I can’t seem to find the schematic online anywhere for this amp. I can find the VTX Heritage schematic but not the VTX Classic series. It looks like the Heritage might be similar to the Classic but I can’t be sure.
One problem was the Potentiometers were very dirty. I removed the pre amp board and cleaned all the pots. No more crackles and pops now. I was kind of hoping the cleaning of the pots would fix the phasing and the issue with the Normal Gain volume. Both issues are still there. When I use the default “Lead gain”, the volume on that channel behaves correctly. The problem with the Phase is still present on the “Lead gain” channel.
The next step for me will be to contact Peavey for a schematic. From Internet searches, Peavey has a very good reputation with providing schematics.
Has any one here had similar issues with this amp?
