2 Days ago, I sat down to start practicing. I fire up the DSL but to my surprise, no LEDs light up. Hmmm. I take it off standby and barely any sound is coming out. This has happened a handful of times since I've bought the amp in 1997 and usually, shutting the amp off and back on after a couple of seconds fixes the problem.
This time, turning the amp back on didn't help. I checked the rear board and the two fuses F1 & F2 were blown. I took out the fuses and rigged up a bunch of wire and fuses to see if the problem was just a fluke. The fuses blew right away.
1) I then disconected the rear board from all of its connections to other boards, leaving only the 22vac supply connected. I fire the amp and the fuses blow again. Damn! This is more serious than I thought!
... and I'm down 4 fuses.
2) I completely removed the board, checked out all of the components, diodes etc and everything checked out fine. Hmmmm. So what's going on?
3) I connect everything back together but leave the 22vac supply from the main board disconnected. Using an old 12vac wall wart adapter, I connect it to the board and voila! All the LEDs light up and the relays work. Good. Maybe there's a problem between the rear board and the tube board?
4) I connect an AC adapter to the main tube board and again, the LEDs light up, the fuses don't blow. Weird.
5) I re-connect the PT's 1st half of the 22vac tap back up and the fuses are OK, LEDs are lit up. I don't have enough fuses to try connecting both 22vac taps at the same time because I'm out of fuses but I'm wondering if that might have something to do with the problem I'm having. I tried powering the board with the other tap and that worked as well.
The only difference at this point is that I'm only using 1 half of the pt's 22vac taps. Could there be an internal short in the PT of something like that that would cause the fuses to blow? Could such an internal short be intermittent?
Help!
Help!
