When setting the bias do you input a 1000Hz signal and look at the harmonics on the analyzer or do you do several spot frequencies?
BTW I also purchased a IR thermometer from HF 1-2 years ago. Now when you use the laser "pointer" to locate/target the meter the temperature keeps rising on the display. It still works okay when the laser isn't used. Works better than my finger tip
![Wink](https://music-electronics-forum.com/core/images/smilies/wink.png)
