This amp has intermittent crackle at turn on that goes away after warming up. The crackle is independent of the master volume so I've been working on the PA. I've done all the following with no fix:
replaced pre and power tubes
banged on amp - has no effect
moved tubes w/ hand - no effect
replaced filter caps
disconnected PI coupling caps to power tubes
replaced power tube grid stoppers
replaced 1.5k 10w screen supply resistors
replaced bias supply filter cap and feed resistors
![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
