peavey tko 115 bass amp circuit
  • peavey tko 115 bass amp circuit
    hello anybody could help me . . I had a peavey tko 115 bass amp and I need a schematic diagram cause a friend of mine tried to repair it . . .problem is that he removed all the power transistors . . driver transistors also some resistors without taking note of it . . . he took all the parts and loose it . . .
    Try contacting Peavey. They're really good about supplying schematics for their equipment.
      Yes, customer service at Peavey wil send what you want.
      Look on your serial number plate and copy down exactly what appears there. There are more than one version of the TKO115, so if it says TKO115 2000, that makes a difference
        thank you so much for the advice . .
        casinolevant levant casino
