Hi all! 1st post in this forum ... a great one, truly a goldmine for information
I bought a used Peavey KB60, schematic is attached below.
It works fairly well, but there are some issues I would like to solve:
- channel 1 is fairly noisy, there is lots of hiss (channel 2 works OK though);
- there is a loud pop when I turn off the amp, which I fear could damage the speakers.
Therefore I decided to refurbish the amp, since i think it is fairly old. A quick look at the PCB shows that it has not been modified, there is still the pencil signature of the tester
I would like to change:
- the electrolitic capacitors, since I heard that it is better to do so after 10-15 years of use;
- the opamps, for some lower noise, better ones;
- solve the issues mentioned above.
So here are my questions:
- would changing the caps be beneficial?
- what kind of opamps would you suggest in place of the 4558s?
- would these changings be enough to solve the aforementioned issues?
- finally, some caps are held by glue. Since I think this can increase reliability by damping vibrations and reducing stresses on capacitor leads, it may be better to use glue on the new caps, too. Which one should I use?
Thanks,
Daniele
Thanks,
Daniele
