I thought this odd, so I'm looking to see if it's typical. Long story short, If I short the reverb send (or plug in a tank that's shorted), I will get an output from the amp that is nasty distortion - even with the Reverb control turned all the way down. It works fine with a good tank or no tank at all. This is a Crate GT3500H and the relevant part of the schematic is attached. "F" on the schematic is the output of the preamps - after the level controls.
It seems odd to me that shorting the output of IC5:B to ground would pull down the non-inverting input with it. If that's normal op amp behavior, it's a good thing to keep in mind for future troubleshooting.
