Peavey mace
  • Peavey mace
    I have a Peavey Mace in for service and i'm wandering what to do about the sheet of asbestos that is stapled to the back panel. I'm assuming it is asbestos, and its beggining to disintegrate. All advice will be gratefully received cos i'm a bit clueless on this.
    You could wrap the entire back panel in three bin bags, throw it away, and make a new one.
    Or you could wet the asbestos so it doesn't give off dust as you remove it from the back panel and replace it with a piece of aluminium sheet.
    I wouldn't try to hoover up the bits, it could just spread asbestos dust around the place.
      I would contact Peavey and ask if that is asbestos sheeting or something else like glass fiber matting... er... glass fibre to you. email Gene Ford, he's a helpful guy. gford@peavey.com
        Spray it with clear lacquer-that's what the radio boys do when confronted with such things.
          Thanks for the peavey man link. Luckily before i encased the whole thing in concrete and towed it out for dumping in the North sea, he assured me the "flame retardant material" was not asbestos. Phew!
            And entire schools of cod thank you.
              Or they would if we hadn't eaten them all.
