I bought this Valvestate Model 8100 head new around 1992 (or so)
I used it often then put it in storage about 10 years ago and recently had a need for it but when I powered it up, the output level seemed low and there was a loud hum.
Thinking the hum was poor ripple from a Bad filter cap leaking through to the signal path, I changed C41, C40, C52 and C59. This didn't help, and actually the ripple was worse and the hum was still there, so I changed C40, and C41 back to the original Caps.
Looking at the output signal, it seems that the Hum I am hearing is almost exactly a 250 hertz Sinewave... in poking around, I think I found a shorted cap (C42) and changed it but the Hum is still there.
In an effort to fix this amp, I am going to change ALL the Electrolytic Caps and continue from there figuring that the age of the amp has something to do with old failing caps and I will get lucky.
Am I chasing my tail with this amp or am I headed in the right direction to get this thing rockin' again?
Thoughts?
I'm attaching the Schematics for reference
Thanks to anyone for some input.
ChrisMek
Thoughts?
ChrisMek
