Hey all!
I have this HiWatt DR103 from a friend in that keeps on having the same problems........ I need some help with this one.
Schematic 1; poweramp
Schematic 2; PSU
It is a nice HiWatt made by Joyce; his sig is in the unit. The former owner never used the amp really loud..... the new owner really pushes it. When this happens (amp is loud, adds a Hartman Fuzz in front of it) the amp suddenly stops working.
When I open her up I notice that the 100ohm resistor between HT1 and HT2 is loose. I fixed her so much by resoldering her in various ways to keep her down but every time I open her up the resistor is loose. Solder free.
I replaced the resistor with a screw down resistor I can screw to the chassis. It is of a greater wattage then the original.
It worked for a while, now the unit blows her main fuse.
Any thoughts on this issue? I use 6CA7's in the amp biased correct (modified the bias section slight to get the right bias voltages). I recapped her but she also had the same issues when she still had her original caps.
Schematic 2; PSU
