I have a 72 Deluxe Reverb which i have had for years. I recently replaced the power filter caps and got a new set of tubes. I am having an issue with what sounds like gurgling static. It is intermittent, the volume and tone has no effect (ie. volume at 0 and static still present), it is a fairly low level, playing doesn't affect it, it only appears about 5-10 minutes after the amp has warmed up, and it goes away when the amp is on standby.
I have started swapping preamp tubes but since it only appears when it has warmed up, it is taking forever. I am starting to suspect it might be the power tubes (i hope!). I was hoping that if someone heard the static it would be a dead giveaway so i am posting a sound sample.
http://www.polishoperative.com/junk/FenderDR_static.mp3
Thanks!
Thanks!
