Ampeg Vl-502 Fade Issue
  • Ampeg Vl-502 Fade Issue
    Hello again,
    I have a nifty Ampeg / Lee Jackson VL-502 head that has a problem that I can't get my chopsticks around. Thought I would solicit some help from the experts here. Thanks in advance for reading my ramblings....
    About the problem: After playing for an inconsistent amount of time and at varied volume (whisper to stage+ level), the sound will become thin and lose all "balls". I had it on the bench and went over the pc boards with my trusty chopstick (while it was acting up & in normal state) but could not affect the sound. I can't force the amp to act up with increased volume (i.e. increased heat). But I can bring the amp out of the problem by engaging the FX loop switch to the In & Out position. Once I realized this, I hit the FX loop board with the 'ol chopstick and again (both states of function) & no luck. I've retubed everything except the power tubes with new or known to be good tubes. The problem was active with the old tubes as well. Cab Impedance is correct.
    About the head: 50 watt ch. switcher, built-in attenuator (not in use), tube everything....fx loop, 'verb (removed tank); EL-34 powered, neat-o light up logo on the front of the head (I'm easily amused....shiny lights...) I have no schematic available.
    Think that's it....Any advice is always appreciated.
    Cheers,
    Lonzo
    But you have already pinpointed the problem. The loop jacks. The cutout contact on the return jack is iffy or resistive. When this happens, plug a spare cord into the send and the other end into the return. I bet it restores the sound.
    I would not be surprised if when it happens, you can crank things and wham out a big chord and POW the sound pops back in.
    A good test is to measure resistance across the cutout contacts. When nothing is plugged in, they touch each other and shiould have about zero ohms resistance. If they show more than that, they need cleaning at least. If they have like 2 ohms or something very low, that won't affect operation directly, but those couple ohms resistance tell us the contacts are not clean, and they wuill screw up eventually. Half an ohm or less is all we will accept as good.
      Thanks Enzo!!
      Thanks Enzo.
      I appreciate your time and advice. I'll check the jack out.
      Regards,
      Lonzo
