Copied a B-15N and the thing hums like crazy. When I pull the first tube it gets way better but won't go completely (could live with that). Changed tubes to no avail.
Plate voltage is 433vdc, grids 426vdc.
Measured the quiescent current over one 1ohm 1w 1% resistor and the DMM said around 30mv (= 30ma) for both tubes (should be around 80 IMHO).
When I turn the volume up the quiescent current goes up to aroung 55ma. Changed the OT primaries and it got a little better (can turn it more up before the thing starts to squeal). Same behavior of changing quiescent current.
Anyone have an idea where to poke around next?
Heres the schem: http://www.schematicheaven.com/ampeg..._portaflex.pdf
