Steve I feel like I'm running up against a wall. I did check the PT as soon as I got the amp and it is set to 120. Today I replaced the main 2X50uf can; now it has three brand-new cap cans, and just for the hell of it I replaced the 100uF/100V bias cap. Also rechecked all the ground straps and resoldered a few just to satisfy myself. Can you guess? (Drum roll please.....) - no difference. If I ground out the PI grids or if I ground out the grid side of the .022 cap feeding the PI, sweet silence. Otherwise, I have a beautiful vintage boat motor. I also replaced both volume pots but I've noticed that if I fiddle with them while the amp is on and singing its lovely humming song, there is crackly static here and there. Both channels - so there is DC getting through to the pots? I replaced those tiny 220pf and 500 pf caps, but I guess I'm going to have to say goodbye to those lovely mustard coupling caps too. I can't think of what else to do.
If there was a grounding problem in one of the LTPI resistors, could it cause this? And if so, which resistor would be the likely culprit? One of the 1M?
BTW - anyone know how this power transformer is supposed to 'read?' It's a lay-down, and the terminals are numbered 1 to 10. What would happen if the rectifier diodes were installed incorrectly? As I mentioned somewhere previously I think, someone replaced the BY128 called for on the schematic w/ two hexfreds. The two negative sides of the diodes are joined and soldered to the red wire which runs to one of the + terminals on the 50uF can, and then the two positive ends are respectively soldered to PT terminals #5 and #3. Aside from the hum everything seems to work properly so I assume they are installed correctly, but just thought I'd doublecheck in the event that someone might be familar w/ this transformer.
This amp has the biggest replacement 3-prong power cord I have ever seen in my life. 14 ga wire was used. Trans-atlantic cable anyone? Whoever did it got the colors wrong but it is just a piece of cable with a replacement screw-together plug as well, and I checked the wire routing and things work out to where they are supposed to be so the colors don't really matter. A standby switch was installed also and it all works properly.
