Hi,im currently building a Blackface Deluxe AB763 with Mojotone chassis/board/transformers etc.All done but have a nasty hum at turn on which dissapears when the Normal channel volume is turned up to a point approx 2/3 on?
This build has a buss bar ground that picks up the mains earth at the IEC inlet and with supports (off the chassis),makes its way through to the input sockets where it grounds to the chassis only here.All ground points are connected to the ground buss as it passes them.Any ideas as to why this humm is there...Ground loop??
![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
