1N914. Or use 1N4148. Mouser has both for as little as 2 cents each.
If you think D3,4 are bad, just unsolder one end of each and lift it from the hole.
Earlier I gave a description of the signal path up to C15. You now mention C8 and the master volume, though they are a ways apart. Did you trace a signal step by step? And if so, where did it lose signal?
What meter are you using? DOes it have a diode test function? That is the thing to use, an ohm meter doesn;t give reliable diode and transistor tests.
And beware good/bad cap testers, they will often show you when caps are bad, but they also often do not show reliable indications of good.
