progress on ab763 build big hum
correction re v1 pin 1 plate current-- the voltage drop across the 100k dropper is about 120v so current is 1.2mA as expected
in answer to grounding questions - preamp filter cap is grounded at input ground, as are pots, and preamp cathodes, tried grounding PI at PT, half way along controls and input, big hum remains
DONT KNOW PLATE CURRENT TO POWER TUBES-- DONT KNOW HOW TO MEASURE IT!
most important/ relevant info - when I lift the output from tube 1 at the 250 pf tone stack cap and connected to the inverter input - the hum remained,, -- I then completely disconnected the input at the PI and the hum remained-- so its in the PI or the Power section!!!
its buzzing but if i turn it up to 1 or 2 it turns into a moog growl, which dissappears when I put a signal through
heeeelp please!
heeeelp please!
