Hi everybody!
Well, still struggling with my L50 conversion. The amp doesn't have the tone controls working anymore, there's interaction between normal and bright volume, bright volume turned down, and bright input used, if i move the normal volume, i have sound comming out???? And the hardest part, the amp is "charging and discharging" like an oscilator. When i feed 1000HZ in the amp i sometimes, but not all the time get bleeep, bleeep, bleeep, raising and decreasing. What could that be??? I've been tracing the signal with teh scope, but it's verry weird. I'm using this schemo http://www.schematicheaven.com/barga...dcity_100b.pdf but it's made in a 50W PA.
Thanks a lot and best regards.
Max.
Max.
