I've got an amp that at least 1 person has worked on & there are a bunch of traces & pads lifted. Quite a few of them could just be glued back down, but some need to be replaced or jumpered. I'm wanting to make these repairs as clean looking as possible, so I don't want to just run a bunch of jumper wires around if I don't have to.
Looking at PCB repair kits online, they seem to cost between $200 & $300. I could literally redraw the board using something like PCB123 (it's a simple 1 layer board) & have a new board made for much less than that!
I have 2 questions:
1. What type of epoxy can you use that will handle the heat of soldering?
2. Is there an inexpensive trace kit that anyone has found to replace 5-10 traces?
Thanks.
I have 2 questions:
Thanks.
