Hi guys, I'm new here, and pretty ignorant about amp repair. I really want to learn to work on these things and joined this forum specifically because the members here seem to be not only very knowledgable, but also very tolerant of noobs.
So, anyway. Here's my first project. It's any early (probably 1994) SWR Workingman's 12 100w bass amp. It blows the fuse immediately on power up. My research has led me to believe that the most likely problem is bad output transistors. I got Fender to send me a schematic, but they sent a schematic dated 2004. I believe that by 2004 the power of this model had been bumped up to 120w. This may be why the component numbers don't seem to match.
I believe that I've identified the output transistors as two 2SC2837's. They are square with three leads and screwed to the heat sink, right? There is a smaller, similar looking component with no markings also screwed to the heat sink, I'm not sure what that is.
Am I on the right track here? Is the correct first step to replace these two transistors? They seem to be cheap and readily availiable.
Here is a picture of the board.
![](http://i31.photobucket.com/albums/c389/spsratboy/IMG_3353.jpg)
The smaller component between the two larger ones is the one I can't identify.
Also, I'm not sure how to attach the schematic to this post.
Thanks, Shannon
Thanks, Shannon
