I have a Peavey Studio Chorus 210. I was playing really loud today. I stopped playing and a wall of feedback came up. I turned the volume down but the loud noise remained. Even with all of the pots turned total left and no cord plugged in, the noise is there. It sounds like feedback (not the high pitched feedback, but the lower smooth feedback) and a volume of 8. All of the caps are from the early 90's I suppose. I was going to start there. I'm not sure how to test anything, I will muck around until I get an answer. Please help me.
Peavey Studio 210
Originally posted by kokain View PostI have a Peavey Studio Chorus 210. I was playing really loud today. I stopped playing and a wall of feedback came up. I turned the volume down but the loud noise remained. Even with all of the pots turned total left and no cord plugged in, the noise is there. It sounds like feedback (not the high pitched feedback, but the lower smooth feedback) and a volume of 8. All of the caps are from the early 90's I suppose. I was going to start there. I'm not sure how to test anything, I will muck around until I get an answer. Please help me.
I had one of those in a while back with a similar problem. Just a whiny noise and the chorus wasn't working as intended.....sounded like a flanger with the feedback maxed. Check to make sure the compander IC is getting the right supply voltages. A missing 15v supply was the culprit there due to a fractured trace. Check for bad op amps as well.The farmer takes a wife, the barber takes a pole....
OK. So I guess no one likes me.
I ordered:
2 MJ15016G
2 MJ15015G
2 SLPX472M035A3P3
and some heat paste.
The transistors are on back order until the first of the year through Allied. I will post an update after the swap and re-assembly. I hope this fixes it. Next I can look forward to the 20 year old speakers to blow. Oh well.
