I cannot find C5198, A1941, C4793, or A1837 for this amp.
I'm wondering if someone can confirm that the 2SC5242 is suitable as replacement for C5198.
http://www.toshiba.com/taec/componen...c//66/7886.pdf
http://www.toshiba.com/taec/componen...c//66/7895.pdf
Also cannot find the complementary A1941... so found complementary to the 2SC5242 which is the 2SA1962.
I cannot find a datasheet for the 2SA1962 but assume if the 5242 works then this should too.
Will the 2SC5171 work for the C4793?
http://www.toshiba.com/taec/componen...c//66/7846.pdf
http://www.toshiba.com/taec/componen...c//66/7870.pdf
Please confirm or correct me if I'm wrong here. Cannot locate a schem for this amp.
