Need schematic for a Crate VC6112
  • Need schematic for a Crate VC6112
    I need a schematic for the crate VC6112. I mainly need to know the specification of the power transformer. Mine is dead and it seems like it is hard to get parts here in germany. Can anybody help?
    Greetings from bavaria,
    Thank you, Michael
    Check Here:
    Follow this link on this forum, found schematics for my Crate BV 120H.
    Schematic Requests [Archive] - Music Electronics Forum
      Crate VC6112 schematics
      Thank you for your reply.
      I have already got it. From Loud Technologies europe.
      1 call, 1 mail, and i got the complete schematics,layout, part list
      - for free
        Did you ask them if your transformer was available?
          Those VC60s had bad pwr transformers. I replaced about half a dozen over the years. They sent the "export" xfmr, which apparently was made by a different mfgr and had both 220 and 117vac primary taps.
            Mercury Mag
            I replaced the PT on my VC6112 a while ago and found that the PT had dual primary windings which were supposed to be connected in parallel for the 120V application. Factory only connected one of the two which ended up taking out the power transformer. Must be the same problem with all the other problematic VC's out there. Anyways, bucked up and ordered the Mercury Magnetics PT and haven't looked back or worried about it since.
              - for free
              Thanks a lot!
                I have the same problem. PT is OK, but it's connection is awful.. "not used" wires are winded together with isolation tape. Connectors on PCB are not used...
                P.S. Sorry for my English)
                  Trying to view schematics for the vc6112. Links don't seem to be any good anymore. Can someone help me with attaining a schematic for a crate vc6112?
                    Crate VC6112 Schematics
                    Here you are.
                      Thank you very very much Jazz P Bass, That was exactly what I needed!!
                        This link doesnt seem to be good anymore. I know this was awhile ago but any way you can post them again?
                          Use the link in post #10. It works.
                            Link : http://music-electronics-forum.com/a...ate_vc6112.zip
