Hello... I've been working on a troublesome Classic 50 (DR504) that was converted to a Classic 100 (DR103) by adding two power tube EL34's. Unfortunately, they never upgraded the OT and it fried. PT also fried because of a power surge, so I replaced both with Mojo 100W rated.
I put in the adjustable bias circuit and that is working. Question is - they never changed the HT2 supply circuit to the DR103 circuit, so there are still 1K5 screen resistors and no 470R 10W. Is that essential to change over for the higher current draw?
There are two big issues right now, I will be checking them out soon:
1. Fairly loud hum (seems like a 60 Hz) that varies with Master volume.. forgot to check if channel input volume affects it also.
2. At running the amp at about 70% up, it starts making a frightning crackling and arcing type sound. I looked at tubes in the dark and didn't see arcing there, could it be PI V4 tube losing bias somehow? I will check that. Any other suggestions?
Thanks
-kdawg
DR103 PS: http://mhuss.com/Hiwatt/Schematics/DR_100wPS.pdf
DR504 PS: http://mhuss.com/Hiwatt/Schematics/DR_50wPS.pdf
DR 103 Output: http://mhuss.com/Hiwatt/Schematics/DR_100wOutput.pdf
DR 504 Output: http://mhuss.com/Hiwatt/Schematics/DR_50wOutput.pdf
Thanks
-kdawg
