Greetings all, any help with my current project would be appreciated.
It is a Lafayette U-80A Muscal amplifier... I've found out that "muscal" is a known typo on the circuit boards of Univox imported circuits.
Anyone got a schematic? It isn't listed as a Univox amp that I can find on The Univox Page
I've replaced all the caps in it and the pots to bring it (almost) back to life. It sounds really good. However, the tremolo is not working. I have found that activating the footswitch will make it tremolo one time, it just won't continue.
It's a circuit board amp, which make tracing it out a PITA.
I wonder if the capacitor types I used were wrong? I used electrolytics for everything above 1 uF, and metalized polyester for everything less.
All the caps I replaced were Atlas Oil capacitors or standard old-style electrolytic... and the oil was all over everything.
Tubes: 2 of 6AQ5, 2 of 12AX7 (solid state DC Rectifier)
Before cap change:
After cap change:
Before cap change:
After cap change:
