I've had this old Roland keyboard amp (Cube 60 -- with silver tolex) for some time now and the reverb has never worked. It's supposed to have a great sounding spring reverb so I thought I'd open it up and have a look. There is no such spring reverb inside, leading me to believe that a previous owner pulled it out.
I have a pretty good spring reverb unit from a retired amp, and I thought I might try to put it in there to see if I can get it to work. Only thing is, I can't find any wires that would go to said reverb box.
On the main circuit board I see two empty places where a cable of some sort could plug in, and they are labeled CN1 and CN2.. This would make sense because there is a REVERB ON/OFF switch for each of the two input channels.
Is anyone familiar at all with this amp? And should a spring reverb unit from one amp probably work ok for another amp??
