Hello, and thank you for looking into my post. I have a Crate GLX65 combo which I have had for a few years. The amp has always worked great until I connected an extention speaker one session. I connected the amp up to a Marshall 4x12 cabinet that it was setting on top of in the session area, and the amp worked fine for that session. After getting home and trying to use the amp again, there wasn't any sound from the resident speaker. I checked the physical speaker connections (which were good) and anything else that I could inspect without opening up the amp to the electronics inside. I hooked another external speaker up to the amp and it worked great. I also hooked up another amplifier directly to the speaker that is in my GLX65... and my speaker works fine. The only thing I can think is that there was a glitch with the External Speaker switch where the amp still thinks that is where sound output should be going. Would sure appreciate any input that anyone can give me as I love the amp and really don't see it being a cataclysmic issue (although it certainly is something that I can't figure out on my own to date). Thank you again for your time looking into my delima
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
